Mobile Network not working
  • Start date Start date
A
Android Question
Guest
I have turned on my mobile network but the 3G sign does not appear and i cannot connect to the internet. What do I do?
Check the APN (Access Point Names) values in you mobile data settings. You should be able to find the correct values from your carrier's website (or a web search). If these are wrong in the handset you'll get no data connection.
