Help mobile network problems
scarfinn
samsung galaxy w unable to activate mobile network (3g). WIFI works, any ideas
have pressed the power button and activated data betwork mode, think i have done the right things in network settings im new and hopeless
it may be from your Network Provider :D maybe low signal or something?
-if this helped, hit thanks please :D
Have you set up APN settings in
Settings/Wireless and networks/Mobile networks/Access Point Names.....??
If you are with your original Service Provider, these should be set up OK...if you are using a SIM from another provider, you will need to set these up!!
You can also choose Network Mode here...leaving it on GSM only will save Battery!!!
But for higher speeds....
GSM/WCDMA Auto is best...
