Help Mobile Network Widget
Chris2183
Member
On my old Eris I had a Mobile Network widget which let me toggle my data off and on without affecting my incoming calls and text. I have been unable to locate one in the marketplace.
If anyone knows where I can find it I would greatly appreciate it.
Juice Defender is the only app I've found to do this right.
Once you've installed JD, got o add widgets to your home screen, and the the 'toggle mobile data'.
Here you'll have the option to turn data off, or set it to the settings you've set in juice defender.
After getting more familiar with the phone I found an option in the Battery Manager section to turn off data automatically after a period of inactivity. It looks that and either Juice Defender or Quick Settings will give me a nice boost to battery life.
