I love Huawei products because they make the official firmware of their devices easily accessible from their website. This can come in handy, you know, for times like these.
After you have the file, you need to extract it to the main directory of your sdcard. There should be a folder named "dload" with "update.app" inside it.
Put the compressed .zip file inside your sdcard aswell, just incase your phone rejects the update.app file.
There are two ways you can transfer the file to your sdcard,
1. Download the file to your PC and then remove the memory card from your phone and place to to your pc .....
2. use Android sideload
To flash the OTA, go to recovery mode and select "Appy update from sdcard ", then choose the file you have just downloaded.
This will hard-reset your phone and restore it to its normal state
