MobileNet connecting problem
  • Thread starter Thread starter kiranraj
  • Start date Start date
K
kiranraj
Guest
Hi im using Micromax A87, My problem is my mobile cant able to connet mobile data. I m enablig mobile data connection but its not working.
Check your APN settings. (You'll have to find your carrier's correct APN settings on the web or call their tech support number). If that's correct, call tech support and ask them to help you (reprovisioning your account - something they do - might help, if there's something wrong with the way the account is set up).
