starkraving
Android Expert
This is not my work. Its something I found after looking through forums regarding the random phone crash.
OP can be found here...
http://forum.xda-developers.com/showthread.php?t=1656529
Thought after some testing I would share this. This will help all those experiencing force closes with the phone.apk. After some research and reading the phone random crash/FC is not unique to the Elite CM9 build. It effected several mdpi devices.
Standard disclaimer... you rooted it, your warranty is void. You use this and any modified software at your own risk.
Direct Download:
http://db.tt/06Cu153y
Instructions...
Download apk
Using your favorite file explorer replace the existing phone.apk in system/app. Don't forget to set permissions (rw-r-r)
Or from your PC use adb ...
If this helps you out hit the thanks button.
Direct Download:
Instructions...
Download apk
