So I got tired of having to manually holding the power+volume keys to go into recovery every time so I added the Recovery menu option to the power menu. Sharing here in case anyone else would like to have it as well. I also took a look at the 4-way boot mod and I personally just prefer having the option directly on the main Power menu instead of a submenu.
Firstly, thanks to Isaacj87 for putting together the MIUI port!
Secondly, thanks to untermensch on xda for the guide.
I REPLACED the Guard option on the power menu so if you like that option, DO NOT use this mod. Basically, you can't change the array size from 5 options to 6 options without the phone crashing when creating the dialog--there's a bunch of verifications on the dialog size in a bunch of different places that is a real pain to try and follow. I didn't want to mess with that so, since I never used the Guard option anyways, I just replaced it--and I don't know how to make a popup window in smali like the Recovery option on CM7 so I don't have any plans on doing that as well at this time.
I also changed the carrier name to MIUI.
In order to see the power menu Phone Options dialog, you need to change your Toggle Settings to Compact view, otherwise, it will just show you your notification bar toggles when you hold down your Power button. To do that:
Settings --> Personal Tab --> Toggle Settings --> Compact
Or as bing7625 mentioned, you can lock your phone and then hold down the power button on the lockscreen.
This has only been tested with Isaac's current 11-30 MIUI builds. Instructions to install:
1. Download Zip file and flash in ClockworkMod recovery.
Download link:
miui_reboot_recovery-1.11.25-11-30-11.zip
http://tinyurl.com/c7tapo5
http://www.mediafire.com/?ha7zauulr97iivj
Undo in case you bootloop:
miui_reboot_recovery-undo-1.11.25-11-30-11.zip
http://tinyurl.com/7nt4lvt
Screenshot of the power menu:
http://tinyurl.com/787u66x
Download link:
