[MOD] Multi-Mod stock JB Deodex {Sep. 28, 2013}
oamilcar
Who is this for?
For those who are running a stock DEODEX JB ROM and want to flash some MODs.
If you are looking for a stock Deodex JB Rom Here is a link for you: (Stock Rooted Deodexed)
These are a bunch of Mods that I am currently running together on my phone. These are all mods that I edited and applied to my stock ROM by hand, and not flashed from other sources.
This MOD is intended to be flashed over a STOCK JB DEODEXED ROM.
Here are a list of MODs with pics that are included in this flash:
-Right clock
-Center clock
-Left clock
-No clock
-Remove am/pm
-Small am/pm
-Large am/pm
-Small abbreviated day of week
-Large abbreviated day of week
-No abbreviated day of week
-Clock color/transparency settings
-Statusbar color/transparency settings
-Removed ongoing notification
-Removed brightness slider
-Removed Bloking mode icon and notification
-Added AOSP style clear-all botton
-Added 23 Lidroid toogles
-Expanded menu options
-Shutter sound on/off option
-Tabbed Settings
-Sense style recent apps
-Ripple effect Enable/Disable
-AOSP lockscreen Enable/Disable
-Show/Hide Alarm icon
-Properly display 1x/3g
-Notification panel background color/transparency settings
-50% transparency top bar of pull-menu
-50% transparency lidroid toggles slider
-50% transparency notifications
-50% transparency pull-menu footer
-Volume Panel Timeout settings
-Long Press to Kill settings
-Rearrange custom options to be @ the bottom of /Settings/Display under Custom Settings and /Settings/Lock Screen/Lock Screen Options under Custom Settings
Thanks to:
-Goggle
-Samsung
-wanam
-Didact74
-lidroid
-loserskater
-bombaybadboy
-tdunham
-Josehg
-Jeetu
-BigSplit
-Others...
For their Guides/links/help.
Downloads:
Deodex
Multi-Mod-Deodex-v4.1
MD5: 1DEBE09BD53C5C5B43C11222F63DFB6E
Odex
Multi-Mod<<< Not supported yet.
Installation:
1-Download Multi-Mod-Deodex-vX.X.zip file from the link above.
2-Check MD5
3-Place the file in the root of your internal/external memory.
4-If you didn't install v2.0, then delete any Settings Shortcut (you can add it after flashing the .zip). If you did skip this step.
5-Reboot device into recovery.
6-Flash the Multi-Mod-Deodex-vX.X.zip file.
7-Reboot device
8-Enjoy
Changelog:
| Sep. 28, 2013 |-Additions v4.1
  • 50% transparency top bar of pull-menu
  • 50% transparency lidroid toggles slider
  • 50% transparency notifications
  • 50% transparency pull-menu footer
  • Fixed notification panel background color/transparency not sticking after reboot
  • Volume Panel Timeout settings
  • Long Press to Kill settings
  • Rearrange custom options to be @ the bottom of /Settings/Display under Custom Settings and /Settings/Lock Screen/Lock Screen Options under Custom Settings
| Sep. 25, 2013 |-Additions v3.0
  • Ripple effect Enable/Disable
  • AOSP lockscreen Enable/Disable
  • Show/Hide Alarm icon
  • Properly display 1x/3g
  • Notification background color/transparency settings
| Sep. 20, 2013 |-Additions v2.0
  • Tabbed Settings Menu
  • Signed SecSettings.apk
  • Sense Style Recents Apps
| Sep. 18, 2013 |-Initial release
  • Right clock
  • Center clock
  • Left clock
  • No clock
  • Remove am/pm
  • Small am/pm
  • Large am/pm
  • Small abbreviated day of week
  • Large abbreviated day of week
  • No abbreviated day of week
  • Clock color/transparency settings
  • Statusbar color/transparency settings
  • Removed ongoing notification
  • Removed brightness slider
  • Removed Bloking mode icon and notification
  • Expanded menu options
  • 23 Lidroid toogles
  • AOSP style clear-all botton
  • Shutter sound on/off option
Disclaimer:
Before you make any changes to your Firmware ALWAYS,ALWAYS MAKE A BACKUP and make sure you download the files that fits your firmware. I'M NOT RESPONSIBLE IF YOU BRICK YOUR DEVICE, flash and follow the instruccions @ your own risk. This MOD has been done and tested by ME.
  • Like
Reactions: Doc
Added:
-Fixed notification panel background color/transparency not sticking after reboot
