rendeiro2005
Hi all
I also decided to start to mod roms allready available for us
Just one more to make your decision harder
Please leave your feedback and thank you all but especially DEVS
This is a mix of:
- Beta4 by zdzihu;
- TRM_Cyanogen6.1.1 by rdannar;
- CyanigenMod6.1.1 by TripNRaVeR.
So, thanks to all of this developers for makin` this possible and for allows us to start playing with rom`s.
YOU SHOULD INSTALL THIS THROUGH xRecovery.
IF YOU`RE NOOB AND DON`T KNOW WHERE TO START PLEASE GO HERE.
THIS IS FOR LATEST BASEBAND ONLY!!!
Included/changes in this build:
- Fonts changed to FlorenceSans;
- Mix of themes (SE/Galaxy S/FroShed) - Thanks to developers;
- AnReboot;
- Astro File Manager Lite;
- AndroidWidgwtClock;
- MUIU Camera;
- GoodMorning Alarm Clock;
- XDA app.
- build.prop tweaks for better battery and smoothness;
- Blade Wifi Fix;
- CM Settings;
- Flash Player;
- MUIU Keyboard;
- Transistions effects.
note: if any of these are payed apps please pm me and i`ll remove right away. thanks
Instructions:
- Make a backup (if you want to);
- Factory Reset (Full Wipe);
- Wipe cache partition;
- Wipe Dalvik Cache (Advanced options > Wipe Dalvik Cache);
- Wipe battery stats (Advanced options > Wipe battery stats);
- Install [MOD][rendeiro2005]Cyanogen6.1.1.zip;
- Reboot;
- Let him reboot one more time and you`re donne;
- Go to Settings > CyanogenMod Settings > User interface > Tweaks extras > Select a theme > Cyanogen
- Install Google_APPS.zip;
- Reboot;
- Due a little bug, don`t config google access at this time. Just press skip;
- Let him proccess cache files for about 10 minutes then reboot.
- Donne.
note:
Latest gapps including Black Market thanks to X10iUser
(if you want i delete that)
Credits to:
rdannar, TripNRaVeR, zdzihu for developing them roms
and
SicNside (smartgardens for pointing that out), mrcharlesiv
Screenshots:
Downloads:
PLEASSE DON`T MIRROR
IF YOU HAVE SOME DIFFICULTIES PLEASE PM ME AND I`LL PROVIDE ANOTHER LINK
v01
v02
v03
After reboot go to - Go to Settings > CyanogenMod Settings > User interface > Tweaks extras > Select a theme > Cyanogen
Changelog on v03:
- Clean almost every apps from rom;
- Flashplayer work after first google account loging;
- Intruduce android stock dialer (to check battery consumption);
- Completed Google Apps;
- More tweaks hopping battery improve and more stable rom;
- Every removed apps and more can be installed from xrecovery (see download codes);
If you want to try my ADW configurations, download HERE, unrar and copy the 2 files inside on the root of sdcard. Press Menu button and then More > ADWSettings > Backup and restore > Restore ADW settings and Restore desktop config
Waiting your feedback
Regards,
Rendeiro
This is a mix of:
- Beta4 by zdzihu;
- AnReboot;
- MUIU Camera;
- XDA app.
- Blade Wifi Fix;
- CM Settings;
- Flash Player;
- MUIU Keyboard;
Instructions:
- Reboot;
- Reboot;
- Donne.
note:
(if you want i delete that)Credits to:
and
Screenshots:
Downloads:
v01
Code:
[URL="http://www.mediafire.com/?dcri1l3ms5a814z"][SIZE="1"][B][MOD][rendeiro2005]Cyanogen6.1.1_v01[/B][/SIZE][/URL]
[URL="http://www.mediafire.com/?r8j98jw6y18vq6q"][SIZE="1"][B]gapps_v01[/B][/SIZE][/URL]
v02
Code:
[URL="http://www.mediafire.com/?v50o6c1qa87mh8z"][MOD][rendeiro2005]Cyanogen6.1.1_v02[/URL]
[URL="http://www.mediafire.com/?e8ca9fk2kqu0jl9"]gapps_v02[/URL]
[URL="http://www.mediafire.com/?x4imi5xpv4qdboj"]CMWallpapers[/URL]
v03
Changelog on v03:
Code:
[URL="http://www.mediafire.com/?8lgfhdc76y4gq4l"]- [MOD][rendeiro2005]Cyanogen6.1.1_v03[/URL]
[URL="http://www.mediafire.com/?3ivd7gki31l9s09"]- Google_APPS_v03[/URL]
[URL="http://www.mediafire.com/?0d7z8w2g4s56mt1"]- Ringtones[/URL]
[URL="http://www.mediafire.com/?bfdjh64faxiqyhn"]- Live Wallpapers[/URL]
[URL="http://www.mediafire.com/?5t46auojmlgwggo"]- Deleted&Addons[/URL]
[URL="http://www.mediafire.com/?mw4c79823j7ddd1"]- CircleBattery[/URL]
[URL="http://www.mediafire.com/?i267n7v2q1q8q7p"]- DevTools[/URL]
[URL="http://www.mediafire.com/?1gb7rbh7bqibn0i"]- DSP_Manager[/URL]
Regards,
Rendeiro
