Zenwafer
So I took one of these -http://androidforums.com/rush-all-things-root/701227-mod-systemui-themed-notification-shade.html#post5653014, stock themed it and greened (it can be a verb) the signals & battery.
There are 2 versions as of this posting:
Solid - STOCKER_RUSH_SystemUI.zip
And Transparent-ish - STOCKER_RUSH_SystemUI_Trans.zip
Install via CWM AFTER MAKING A BACKUP!!!!!
I did my testing on Stock Deodexed [Rom] Stock - Android Forums
& Blu beta [ROM] G-Rush Blu beta2 (Light & Dark) - Android Forums but that does NOT guarantee a single thing when it comes to you and your Rush which is why I will again tell you to MAKE A BACKUP IN CWM BEFORE FLASHING!!!!!
The only bug I've found is with the Mobile Data toggle. Sometimes it says some trash about inserting a SIM, but a full reboot got rid of it for me.
The white clock was done via Tweakbox, which can also change your 4 bar signal into a 5 or 6 bar. I mention this because I left the 5 & 6 bar signals grey. Why? Well they turn back to null when your signal is strong & my left eye started twitching when I first saw it on the 5 bar so I tried the 6 and it was the same. So I just left them alone, went back to the 4 bars and tried to forget that it ever happened. If you simply can't let it go we can burn that bridge together
Thanks to K Rize for the original MOD and Christophorus for the CWM flashable zips I use oh so often
Edit - This was for made for ICS ROMS
