[MOD] Themed Asus Dual Battery Widget - V2.0 Released
AWESOME!!!!
Thank you!
So much better than the stock widget!
Quick question though, how do I uninstall it, incase I want to get rid of it in the future?
Or if you update it, should I uninstall it first, then reinstall the new one?
Where is the widget located in the filesystem??
Does the custom widget's wallpaper reflect the current wallpaper in use on the prime? or does the wallpaper stay the same?
Thank you again!
AWESOME!!!!
Thank you!
Thank you again!
The wallpaper is static, meaning its what I put in there. I don't mind doing custom jobs but you will need to send me a screen shot of what you want on the widget.
Un-install like you would any applications in the settings/applications location. Its called asus Battery 2.
updates: These can be installed right over the top without even having to remove the widget from the home page. It will update.
Glad you like it.....XDA has more customs as well.
Sorry you had issues, while one of the items you mention in here is a known issue and I used to list it, it was solved by an Asus update. So I would be curious of what version you are on. The known issue was using asus file manager crashing when opening the directory with an APK in it. It did not happen to all apk's but certainly happened on this one. But was fixed with the latest OTA .14 (Just tested again and was working). The work a round was to load astro file manager or any other file manager and you are able to open the directory. You are the first of about 1000 people that have mentioned having video issues after loading my widget. I will keep an eye out on that though i play videos all the time and have had no issue. Again I am sorry to hear you had issues and hope they get worked out. And I would still like to know what version you are on....if it is .14 then I would like to know the exact widget you downloaded.
Thanks.
SirSlayer.....Thank YOU for the great followup. I'm running Android version 4.0.3 (ICS) I did the OTA update the second day I had my Asus TF201 (Prime). My build number is 4.0.3-WW_epad-9.4.2.11-20120117
As to which ones I tried to download I remember it this way....It said that the custom ones could be downloaded 'over top' of the other one....so that is what I tried to do. I downloaded the original one (Dark Gray), and then downloaded the first 'custom' one (Grey).
I wish you all the best as a dev. You obviously care about the users of your product and I'm sure it's a fine app.
