Root Mod xposed installer/ Xtheme engine
Here is some screenies
Hey guys i found this mod and it will give you some awesome mods here is the link for it.http://forum.xda-developers.com/showthread.php?t=1574401
Just follow the instructions its so easy a noob couldo it.
And for the Xtheme engine its basicly like the tmobile engine theme which you could theme your phone here is the link http://forum.xda-developers.com/showthread.php?t=224018
For the theme here is one that i tested it works ill post screenies here is the link for the theme http://forum.xda-developers.com/showthread.php?t=2251952
Download the one that says chrominum and install it as a normal apk
More screenies
XThemeEngine Says it needs root but Superuser never asks me to give it :/
Change your Superuser app.
From http://forum.xda-developers.com/showthread.php?t=1965781
1. Install SuperSU from Play Store.​
2. Open SuperSU and grant it SuperUser permissions (important; if you delete SuperUser before you grant rights to SuperSU you lose your root and need to either reflash the ROM or flash the zip I linked above).​
3. Delete SuperUser from /system/app with a root file manager.​
Read more about chainfire's SuperSU here: http://forum.xda-developers.com/showthread.php?t=1538053
