Is there a way to get more home screens with the default home instead of using ahome or other alt home apps? The other apps dont allow u to use all the widgets i have downloaded and i want to use them. Any tips?
The 3 screens is what you get currently with the OS .... Widgets are usually devleoped to work with one HOME display system at a time .. and mostly are not interchangeable...
