Moisture Detected - Strange daily behavior
MetaLore
Something odd is happening with my Note 10+. Every morning for the past few days I'll pick up my phone and use it for a few minutes and the Moisture Detected message shows up in the notifications bar. I'm positive there is no moisture. I'll reboot and after a couple minutes it goes away, but immediately when it disappears I get a notification that T-Mobile Visual Voicemail could not connect to my voicemail box. It's always at the exact same moment one message is replaced by the other. I can't imagine how they would be related.
can you take a screenshot? i looked in the icon glossary that can be found in the phone's settings and do not see a icon for moisture.
Hi there MetaLore, and welcome to Android Forums!
I don't know if this will solve your problem, but a method I read on Samsung's site, involving Q-Tips and rubbing alcohol, seems to work well for others. Check it out and see if it helps!
