- Every time I charge the Moment, the backlight never turns off unless I press the end button.
- When the Moment is not charging the backlight will turn off after 30 seconds according to my settings.
- When put the phone to sleep and the Moment fully charges, it "wakes up" and stays awake or until I turn it off using the end button.
- robooting the phone, nothing changed
- used ATK, nothing changed
- let the battery run out 2 times, nothing changed.
Is there some solution to this problem?
What should I do.
