The script will go trough 3 stages of test and -if pass -will actually begin the "magic". In windows, I could not pass the stage 2. It hung up because the Sync Manager breaking connection with the script. HTC and Tmob, wanted to make sure that we will not be able to uninstall the bloatware with S=ON. I could not uninstall it. Every time I remove, it will come back after reboot. Finally I give up on Windows and "plunge" into Linux. Do not get me wrong, I got scare few times, but all went fine. If you decided to install a Linux then download the script from Linux. It will put into /Home/Downloads dir.
Right click will get you options to extract. Then, from root terminal cd /home/Download and the dir that was created. Just fallow the instruction on moonshine web site. LIke I said before, I am not much into a Linux, and I believe that if I can do it, then any one will.
