Mophie juice pack battery case
Thanks. Do you know if the slim extended batteries that fit inside the stock battery cover are any good?
They're on a user to user basis. Everyone has a different experience. I would suggest to look for some on Amazon so they're cheaper and check the ratings so that you can gauge whether it's worth it or not.
