More Questions
mbmast
Member
I am back again with more questions. You guys shouldn't be so helpful! ;)
Droid X2
Memory ~ can I add more memory to my phone? Since I have downloaded music, which I haven't even used up the 11mb yet, my phone has slowed way down.
Basic Camera ~ I am still having problems with this. It is extremely slow and will shut down automatically.
Pandora ~ I was reading posts regarding Pandora and data usage. I do have WiFi. However, if I have it on the Pandora still uses up my data time. Is there a way to set up Pandora so it only uses WiFi? Pandora also skipped or started a new song in the middle of playing current song. Any suggestions regarding that?
Voice Control ~ I have friends that say they can say voice commands such as call so and so on mobile. I haven't figured out how to do this yet. Any advice?
Thanks so much for your time and help, it's greatly appreciated!
memory - you can add an external sdcard but what you might want to do is move your music to google music. You can stream your music via wifi/3g and not have to worry about having anything on your phone.
camera - my friend has an X2 and she had to exchange it because of camera issues. I'm not surprised to see that it crashes on you but i'm not too sure what you can do, here. if you feel up to it, maybe factory reset your phone and see if that fixes it (make sure you backup first because that will wipe everything)
pandora - pandora app has a bug that will skip a song in the middle of playing. its happned to me and a lot of other people. Nothing you can do there. You can't configure it to ONLY use wifi. If you have Wifi turned on, you really shouldn't be using any significant data (maybe a tiny bit if your phone needs it to talk with the provider .. but very little to none)
voice control - Sorry, can't help you there. I dont use this feature at all.
How do I move it to google music?
I tried that once, it helped for a little bit and is now acting back up again.
Good to know, thank you!
That's ok, I still appreciate your time!
thank so much!
thank so much!
1) install the google music software on your computer (not the google music app for your phone). Upload all your music via that software. Once thats done, you can listen to all your songs via the mobile app.
2) sounds like its a problem with the phone. If you feel adventurous, you can try a custom rom. Maybe that will fix the problem.
3) :)
4) i see the poster above me suggested Vlingo.
