Motherboard and Water Damage Questions
Hello, my samsung galaxy s3 recently took on some water damage to the mother board. I want to know if I can buy a motherboard without the chips, and just swap my chips onto it, or is that not possible?
Id try n find someone selling an s3 on Ebay etc with a broken screen for a nice cheap price ;)
As long as u know your display is ok, thats the most expensive part tbh and you could just put your display onto the other ones body :thumbup:
P.s, the swapping chips thing probably isnt gona happen realisticly. The mother board IS a bunch of chips :beer:
The best that I can find is one with a broken lcd for $150, but that is the same price as the motherboard, and are you saying that it is impossible or a waste of time to switch the chips, because i have a ton of spare time?
They are soldered to the main board. This would entail a ton of effort to break the solder points and the resolder everything. Best bet us to find one with a broken screen and then swap the screens.
Sent from my SCH-I535 using Tapatalk 4 Beta
