Help Motherboard replacement procedure
supersi
I have a 16GB Galaxy SIII GT-I9300 international.
A few days ago it started repeatedly rebooting. The reboot frequency increased until it would not reboot at at all.
I tried a number of fix suggestions. None worked.
None of the software/firmware fixes will work because the phone simply won't switch on.
I believe the problem is with the motherboard memory. The phone is a month out of warranty so I don't think Samsung will fix it for free. Besides, I opened the case.
I'd like to know exactly how I can can make sure I order the right replacement board and and what other steps I need to take to get phone working. Fortunately I have a full SD card backup
What country are you in mate? I think your best bet would be to buy a scrap s3 with broken display and put your display on it. It has to be a gt-i9300 :thumbup:
