You will do a Fact9ry Data Reset before you turn it over to a third party. When you do you might find that it corrected the problem.
The "buttons" on my Druid Maxx stopped operating once. I was preparing to get it replaced and did a Factory Data Reset. It corrected the problem and it never happened again.
... Thom
It was Amazon but they don't have any more at the same price. I'll try the factory reset and then if that does not work, figure out how to exchange it on Amazon. At least they are good to work with! Thanks.I'd say you've got a hardware issue. Did you buy it used or from amazon or Moto? If new from Amazon/Moto, you should be able to do a warranty exchange for it.
Yes they are good to work with. I agree, try the factory reset first, like Thom suggested. As far as your contacts go, as long as you made them Google contacts rather than on the device they should be copied to the Google cloud. You can easily check this by logging into gmail on a computer and looking at your contacts there. Of they match you're good to go.It was Amazon but they don't have any more at the same price. I'll try the factory reset and then if that does not work, figure out how to exchange it on Amazon. At least they are good to work with! Thanks.
So Amazon won't replace it for you? Not even with a 2nd gen version?Sadly, the reader did not work so back it goes and I am unable to find another one. Thanks for the input.
Ah, OK. I didn't realize you have a CDMA device. Mine is 1st gen GSM version that I had bought direct from Moto.Wasn't an option when I went through the return/replace drill. There are none to be had and the second generation are GSM while first generation are CDMA, which is what I need on Page Plus
Nice!Just a quick update. I called Motorola tech support and they could not fix the issue so they are going to exchange it for a new one. All might be well that ends well.
