Help Moto G4 (Plus) nougat
RickKode
Hello, I have the Moto G4 Plus, with mm. But some sites say nougat is released, some say it isn't, I really don't know if it it or isn't. (I live in the Netherlands btw)
Looks like Nougat has been released for the Moto G4 and G4 Plus, here is the announcement:
https://motorola-mobility-en-in.custhelp.com/app/answers/prod_answer_detail/a_id/115401
Android is released to phones in stages, not every phone at once, and I'm not sure how being in the Netherlands will impact when you get it.
If you have not received a notification message for this update, follow the steps below to manually update your phone:
  1. Select the Settings icon in the apps menu.
  2. Select "About phone".
  3. Select "System updates".
  4. Select "Yes, I'm in". After the software is downloaded, select "Install now".
  5. After the software is installed, your phone will re-start automatically.
  6. Your phone is now updated.
