Moto G5 Plus - How to block phone number
GamerCore
Nobody likes receiving unwanted calls, but the Moto G5 Plus makes is super easy to block phone numbers. Let's take a look at the two methods:
Method 1
  • Open the Phone app
  • Tap the 3-dot menu in the search bar
  • Select Settings
  • Tap on Call blocking
  • Tap ADD A NUMBER
  • Enter the phone number you'd like to block and tap BLOCK
From the Call blocking menu you can also unblock a number you've previously blocked by tapping the X that's on the same line as the number then confirming you want to unblock.
Method 2
Another easy way to block numbers that have called you is doing it straight from your call history:
  • Swipe left to your call history/log (middle tab)
  • Long press on a phone number
  • Tap on Block number
  • You'll see a prompt asking you to confirm blocking that number. Tap Block.
