AMTrombley0924
So this is my first Android device with Moto ["not"] Blur. I'm seeing some icons in my notification bar that I don't recognize.
The one that I see most often is as follows:
It is located between the battery icon and the time (second from the right). Is is a black square with a grey outline and a grey check mark inside it. I doesn't show up if I pull the notification bar down.
I though it was Smart Actions, but when I turn it off, the icon doesn't go away. Also, when an Action is active, another icon that actually makes more sense shows up, so this mystery icon isn't associated with Smart Actions.
I've looked through the User manual, but haven't found anything on it. If anyone who's more familiar with blur know what this is, it would be a great help. Thanks!
