Help motorola defy and screen issue
my screen is real dim after it got if i hold it to a light i can see screen its not cracked or nothing so what part i need to fix this
There are ways to adjust the screen brightness.
On the Home Screen, if you press the circle at the bottom in the middle of the screen it should bring up the screen of installed applications.
"Brightness Level" I think that is an installed application I have found.
However, if you press the menu button (4 squares, one coloured in, bottom left button) and choose "Settings" then "Sound & Display" and scroll down to a box labeled "Brightness". Mine is set to "Automatic Brightness" but you can uncheck this and choose the setting yourself, or check it and it will do it itself...
Good Luck ;)
