Help Motorola droid and clockworkmod recovery
briansurg
Please help. I can't boot into recovery 2.5.0.1. I updated to the most recent Cyangen mod, and now I can't boot into recovery. When I go back to 2.5.0.0, things seem to work fine. Any suggestions?
Original Motorola Droid
Thank you in advance.
Try flashing the latest ClockworkMod recovery, then scroll down and flash "alternate recovery" (SPRecovery). Then flash the latest ClockworkMod AGAIN. Should "stick" then. Let us know how it works out for you.
For some odd reason, ClockworkMod is finicky. It's much more versatile than SPRecovery, but it can be a pain to get it to "stick". Flashing as you did, you should have no more problems, though. I have not had an issue with ClockworkMod for the many months since I did what you just did.
If it doesn't stick once, flash Sprecovery then flash Clockwork again.
If that doesn't work, flash SPrecovery, reboot, flash clockwork, reboot again.
One of these two steps has solved almost all cases of CWM not working correctly on phones.
Nevermind, fixed it. Sorry for the bother.
So it is not working again. Now when I try to flash ClockworkMod, it says error while downloading from server, please make sure that you have a stable internet connection and you have free space on your SD card? I am connected and have free space, so any other suggestions? Thanks in advance.
