Motorola Droid FAQ's
Status
Not open for further replies.
D-U-R-X
turbo drinker
This is a work in progress and, as such, if you feel that there is anything that needs adding, please PM a guide or start a thread in Private Chat With Staff with your suggestions.
Many thanks :)
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Droid Tips & Tricks?
4. What are the known problems with the Droid?
5. Forum related questions.
6. What is root?/What does being rooted mean?
7. How can I fix/replace my screen?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: First off, you should read this thread: Battery Life or this thread: Android Battery Should Last All Day according to Google's CEO. You do not have to follow all of the tips/suggestions, but the advice is sound and will help. Smartphones operate on a sort of spectrum. On one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Q: Are there any Droid Tips & Tricks?
A: You should check this section out Droid How to and Tips
What are some of the problems people have with their Droid?
A: You should check out Droid Support & troubleshooting
Q: How can I fix/replace my screen?
A: This thread has step by step instructions: How to repair Motorola Droid screen
Status
