soradreams
Hi all,
frome some days it happens when the phone is charging (when it on) the battery doesn't charge. Let me explain, the main screen says "in charge" but instead does not load .. However, if I put it off loads normally.
In addition, I noticed that smite will discharge faster than normal plus the USB cable when I connect to pc does not work .. and the same problem charging do it with the PC.
You too have happened? What do you advise me to do?
thanks
thanks
