motorola.hiddenmenu and contacts issue?
howtodo?
OK so what is the Motorola.hidden menu and what purpose does it serve.also the first day ibought thedroid I was able to store my contacts in the original contact area,nowafter snycning fb my contacts r stored in all contacts folderhow do I get them to store under contacts again?
The hidden menu has been mentioned on other forums. If to use a task managing app to 'switch to' it will ask how you want to open it and if you thumb through the list of options it gives you to open it you'll see that it allows you to access area of the phone you wouldn't normally be able to access.
I never opened it so I don't know and I just deleted the task killer app. But it would always pop up so I was curious. And what's the good word on this contact issue anyone else have this happening or a fix?
