ShinySide
Extreme Android User
Motorola needs Photon 4G testers for a new update that they'll be rolling out. You can read more here:
Photon 4G Testers Needed
That was posted at the end of last September. Not sure if there are openings presently, or not. I'm not even sure if there's a current or eminent testing opportunity.
EDIT: Looks like another round of testing IS eminent.
There's a leaked 198_7 build over at XDA which I've been running for weeks (must be installed with RSD Lite--NO root required). If you install it, make sure all your apps are installed before doing so, and don't wipe your phone. Some of your apps will disappear from the Market after doing so because the ROM fingerprint isn't approved by Google yet. Other than that, the build's been solid.
Anyone use the test update that has re-rooted their phone afterwards?Motorola needs Photon 4G testers for a new update that they'll be rolling out. You can read more here:
I tried the method I used before and it is not working...I used a one click method before and it worked great and then reverted to the stock rom to try the update and I don't think there is any thing great about it and want to root it again. anyone have a working method?
I am a real noob to this stuff but manage to get it done with good directions
ThANKS!
