pittguy578
Member
I love my new phone, but I HATE the battery life. I didn't even use it last night and it was fully charged when I put it down around 7 PM. I wake up this morning to a very low battery.
Is the battery life on the Motorola better?
however... I find if I charge my phone overnight and take it off charge at, say, 9am it'll last the entire day and through the following night without needing charging. You can check your "awake" time in the phone settings menu to see if some application is stopping your phone from sleeping properly. Although it won't tell you what's causing the issue at least it'll tell you that something software-based is the culprit!! From the home screen select menu, settings, and then I can't quite remember! It's something like "phone info" and is at the bottom of the page.
