Help mount usb storage issue
varun.chitre15
Android Expert
when I tried to mount USB via recovery it gives an error:unable to open ums lunfile(invalid file or directory)
any solution?
its because of no data in phone.....do this first install rom and reboot and then go to recovery then it will work
this happens to me everytime when i flash roms for testing not meant for my device
still I have not installed ur ROM I m on stock ROM nd want to install ur ROM bt can't bcoz I have wait for 8gb card ordered from let's buy nd I have just 1gb card presently nd it is messed up with all other contents. bt why should this happen on stock ROM. any other soln if not please tell it in detail.
and yes I m on stock ROM and installed log cat and I m also getting a same error in it i. e akmd2:device can't be opened.why is this so.is it bcoz of ur kernel or what.answer my first post also.
it is not a kernel problem...it is a sensor problem...replacing file or deleting that file will fix it
any other error
