No. Just buy a card. 8G SD cards are really cheap.Could I create a "fake" SD card inside the internal storage - eg make a symbolic link from /mnt/sdcard to /mnt/flash/sdcard? Or is it more complicated than just that?
# rm -r /mnt/flash/sdcard
# ln -s /mnt/sdcard /mnt/flash/sdcard
link failed Operation not permitted
I don't think this will work anyway because the internal storage is probably FAT32 so doesn't support Unix permissions, symlinks, etc. So...'Operation not permitted'. You'll have to format the partition.
#dd if=/dev/zero of=/mnt/flash/abc/sdcard.img bs=4096 count=50000
#mkfs.ext4 /mnt/flash/abc/sdcard.img
mkefs -t ext4 /mnt/flash/abc/sdcard.img
busybox mount /mnt/flash/abc/sdcard.img /mnt/sdcard
#dev_mount sdcard /mnt/sdcard auto /devices/platform/AMLOGIC_CARD/card_host/memorycard0
#dev_mount flash /mnt/flash auto /devices/virtual/mtd/mtd3/avnftl3
dev_mount sdcard /mnt/flash auto /devices/virtual/mtd/mtd3/avnftl3
Not sure if you're still looking for a solution to this problem however there is an easy one.
I have a Zenithink ZT-282 C91 and I accomplished this by simply editing
/etc/vold.fstab
I just commented out the two lines that normally mount /mnt/sdcard and /mnt/flash then added a new line that mounts the /mnt/flash device to /mnt/sdcard. Works fine with all apps I've tried and also has the device see it completely as an sdcard.
