Kroegs
We all know this device isn't affluent with internal memory. I've been playing around with mount2sd and partitioning the sdcard with fat32 for the primary and ext3 and ext4 on another try for the secondary for mount2sd. When the startup script is installed the fat32 section becomes unviewable on my pc, though it definitely exists via viewing it with es file explorer and even cwm.
Also, I can use minitool via my old original warp but it doesn't work at all on the warp 4g. AParted does work ok, and is kind of neat partitioning on android, but it's really odd and it may have something to do with getting mount2sd to work properly with the warp4g. If anyone has any insight it would be greatly appreciated.
