Hmmm sadly the download was removed. :\ any other suggestions? this is a new phone i just got i cant mess it up this quick
reflash with ODIN, ive encountered this error flashing rfs rom's with req0's ext4 kernel.
Download mode:
1) Unplug USB, remove battery
2) Re-insert battery
3) Hold down Camera button (you do NOT have to hold the Vol Down button)
4) Plug in USB
5) Keep the Camera button pressed, after 4 seconds, the phone will go into download mode.
6) If you don't get it, try again.
Basic ODIN instructions:
1) open odin
2) put your phone into download mode
3) connect the phone
4) ensure that you have a yellow com# box (see pictures in post #3)
5) Select the ops file in the ops box
6) in the checkboxes in teh top left make sure one package and auto reboot are selected
7) in the bottom one package box select the desired tar
8) click start!
Files needed:
ODIN:
Odin Multi-downloader + r720 .ops file
flash one of these via one package option.
first one is stock unrooted.
second is stock rooted.
EH02:
PURE STOCK PDA:
Stock-PDA.tar
^^^ this will wipe
EVERYTHING.
Pre-rooted PDA:
Prerooted-PDA.tar
^^ this tar is pre-rooted just flash, download superuser from the market and youll be good to go
this tar does
not wipe your data
youll need to flash this via one package option:
admire-cwm
if it's not a ROM that has an overclocked kernel or needs to be formatted as ext4, you should be using cwm 5.0.2.7 (admire-cwm.tar).
alot of people have run into mindless flashing and reflashing and bootloops using the 5.0.2.8 recovery for the wrong ROMs.
(i know i have.)
