Move contacts from Nokia to Android
I bought SamSung Global and need to know if it is possible to transfer from Nokia mobile the contact, Calander and SMS messages i.e. Inbox, Sent and Draft items. Your advise will be appreciated.
Regards
On the Google Calendar page, click the Other Calendars arrow then click Import. There, it says “Choose the file that contains your events. Google Calendar can import event information in iCal or CSV (MS Outlook) format. Learn more."
So if your Nokia exports to one of those, it can be done.
Install Ovi Suite on your PC and backup your Nokia phone. Then install Samsung Kies for PC then go to tools and select "restore from Nokia device"
