Move files from Android folder to SD Card
Hi,
I installed Fifa 14 on my Android and the game is located inside the Android/data and its around 1.5gb in size but I would like to move it to my SD card to free up some space.
Although I have copied the game to my SD Card from the Manage Apps in setting obviously it wont moved this large file.
Is their any way I can move this file to the SD Card without causing issues with opening the game?
FYI: I have rooted my phone as well if that helps?
