move from SD to phone memory?
is there a way to move apps,games, files whatever from the SD card to internal phone memory? (droid 2)
whenever i search it from phone to sd always comes up, i wana know if theres a way to move from sd to phone
thanks
Are you asking if you can move apps to the internal memory from the SD card? If it is just go settings -application -manage apps n you will c that option
not so much apps, but more specifically like music files and some games where you need to DL files to the sd card. i kinda wana move some of that stuff from the SD card to phone memory. just cause it seems most stuff goes to the SD and i wana use some phone memory instead of all the SD
