Help move slider with widgetlocker
rehpyc
how do you move the default unlock slider to another position on the screen? it seems i moved it towards the bottom, and now i can't figure out how to move it for the life of me.
Go to the app for widget locker, press menu > settings > look & feel > slider & layout and put a check mark in "no slider". Then back on the main widget locker screen long press on the screen and select "custom slider" and place it where ever you want.
Also, the "WidgetLocker" slider style in the settings allows you to reposition the slider. The "Android" slider style does not. The "Android" slider style is in a fixed position.
