Move to Sd S7562
Can anybody help me finding solution to move applications to external sd without rooting mobile samsung s duos (7562)? Nothing works for me, i have tried move 2 sd, link to sd and many other apps but all in vain. Help me please.
Hi ABCamargarth, and welcome to AF :)
What android version are you running? The feature was removed early in android 4.
Go to settings > apps > downloaded, select one of your apps, and if there isn't even a "move to sd" button then you won't be able to do this without rooting.
A quick Google shows this is a dual-SIM phone sold in India with Android 4.0. Root is probably required.
Link2SD will only work on a rooted phone and needs a second partition on the SD card before you can use it to move apps.
