Hello all,
When I watch movies loaded into my phone (milestone 720,2.1) the screen is half full. There appears to be more room on the display but it only fills the center of it. How can I get the movie to fill the screen? Apps or Widgets?
There might be an app that will resize to your screen but I can't think of one off the top of my head. You could also check to ensure that videos are encoded with the proper resolution for your device.
Sounds like you watch movies on your phone? How do I load the digital copies I get when I buy a blu-ray onto my device? Is there a cheap pay-for-app that does this? Or does the disc itself that has the movie also has the program to do it?
Usually you can only move digital copies to devices supported by the distributor/studio. Most only go as far to include iPod, Zune, and in some cases PSP.
I don't think many, if any, have added the android to be compatible with their DRM
