MoviePlayer app name/values help!
Jjtee45
Hi guys, firstly thank you for your help in advance. I recently bought an android box which has MoviePlayer built in as standard. This plays files far better than Xbmc, and as such I would like to call it in Xbmc as my external player. However, for the life of me I can't find the values/actual name of the app to use as an external player. For example mx player is
com.mxtech.videoplayer.ad
I'd like this information for the default "Movieplayer" 1.73.
Included are screenshots of the app
Thanks again!
Use almost any app that will give you a list of installed apps such as link2sd, AppAsst, or whatever. Most seem to be able to display package filename either in the list or when you tap on it to view details/properties.
