SHMaRiM
Member
I've had this app since it first came out. Thought I'd write a little review and then link you to where you can vote to fix the only major problem I've found.
Pros:
Here is a link where you can vote to fix forum text issues...
Forums on Mobile Beta
Pros:
- Fast! Seems much faster than "stock" internet app
- Customization and Add-ons! Ability to add personas (skins). Also able to add features such as adblocker (blocks ads
), Tapsure (tapping a rhythm for password instead of entering in text every time), NoScript (web security)...etc. - EASY navigation! Hidden slide out tabs bar (easily close tabs). Hidden slide out bar with back/forward buttons, settings, and favorites.
- Supports many full versions of sites that the normal browser does not (even with "mobile view" unselected).
- Downloads, site options (find in page, save as pdf), Add-ons, and preferences appear when "MENU" is clicked on phone.
- Lots of preference options for further browser customization and performance tweaking.
- I've noticed some annoying problems with the text input on certain pages. At first the cursor was jumping and was causing me to type jumbled words, however, I'm pretty sure they fixed that since it no longer happens. Also some forums and such don't allow you to enter text in reply box unless "advanced reply" is pressed. Then on advanced reply page I've noticed when in the text box the screen zoom continuously changes and makes it VERY distracting to type.
It kind of reminds me of those fun old frontier days when computers were new.
