My husband and I both got the 32 bit galaxy s6 edge. We downloaded the same mp3 apps...his loads tons of music and works perfect....mine won't even return songs for a search. What's wrong?? Is it something in my settings??[/QUOTe
Mine does the same.It seems no mtter wha media you download ,whether ringtones,picture,mp3s, wallpaper the are saved te th internal storage.Some reason the phone does no see any files saved to the internal storage, I used the samsung Myfile app to check where the files were downloaded.I even moved the to the correct folders and they would still not show. Noapp will see them ,music player, gallery ect ringtones or notifications.I read somewhre you had to hav root access .I'm not sure what to do.Wish someone could help
passwords doesnt matterDo you have usernames and passwords for these apps? If so, are you both using the same username and passwords? Longshot but that might be the problem. It's also possible he is messing with you, give him hell and don't feed him for a week. That might do it.![]()
Delete .nomedia file in the music folderMy husband and I both got the 32 bit galaxy s6 edge. We downloaded the same mp3 apps...his loads tons of music and works perfect....mine won't even return songs for a search. What's wrong?? Is it something in my settings??
Thanks mate. you have a great mindFound the solution.Called samsung and they had no idea. But I'm well versed on android to I finally figured if out. Open up file manager. Hit device storage.Scroll down and find .nomedia file and delete it. Restart your device.Any folder that has a .nomedia file in it will never be reconized by any app on the phone. It wasn't in a specific folder, it was in the my files manager home so nothing from the internal storage would show up .Now my pics,ringtones ,videos,and mp3s all show up.good luck
Open the file manager, find the folder that the music is in. Click on the cd folder. On top click "more" and then "show hidden files" and then you should see the filedHi there,
I am having the same problem but I cannot find this .nomad file you are speaking off on my s6 edge. If possible could you list the steps from the home screen of where this should be thanks
Download a ringtone maker app In the Google play store, snip as much of the song as you need, and toy should be able to select it afterThank you very much got it now.
I have another question I downloaded a song from the play store and would like to use that as a ringtone is there anyway to do this as with my s4 it was just a case of picking it and that was it but when in the ringtone section a searching for more, the song I have downloaded does not show up
Thanks again
Turn off developer options and then u can dl music. Same thing happened to my wifes edge plus. I have the note 5, we downloaded the same music downloader, mine worked fine. Hers would load any songs. I dug around in her settings and turned off developer options and hers is now working fineMy husband and I both got the 32 bit galaxy s6 edge. We downloaded the same mp3 apps...his loads tons of music and works perfect....mine won't even return songs for a search. What's wrong?? Is it something in my settings??
