Mr./Mrs. Block Walkthrough
I am stuck on Level 35 but I decided to start over and post the solutions to the game as I do them. There are four sections, nine levels in each for a total of 36. The game name is confusing as the icon on my screen says Mrs. Block and when the game loads it says Mr. Block.
SECTION 1 - Levels 1-9
Level 1
Click on the red block. Use the arrow keys to move it either left or right into the colored space. It's the same distance (11)
Level 2
Click on the yellow block and move it to the left through the red block and then to the right on the bottom in to the yellow colored space. Then move the red block. (24)
Level 3
Click on the yellow block and move it to the right till it can't move any move. Click on the blue "eye" at the bottom right and turn it into stone. Click on the red block and move it to the right. It will drop down on the new stone. Then right into the red space. (9)
Level 4
Move the top left red block down to the bottom and then all the way to the right. Turn it into stone. Move the bottom right yellow block on top of the new stone and turn it into stone. Move the top right red block down into its space. Move the top yellow block down into its space. (14)
Level 5
Move the bottom two yellow blocks so that they are just to the left of the yellow open space (not under it). Turn them into stone. This is so the top yellow block has a path to move on. Move the bottom blue block down under the yellow space and turn it into stone. Now move the top yellow block into its space. Move one of the top blue blocks down on the new stone block and turn it into stone. Then move the last blue block down into its space. (16)
Level 6
Move top left red block down and into its space. Move the grey block over uner the blank red space. Move the top right red block down into its space. (12)
Level 7
Move the grey block right and to the right wall. Move the right blue block on the grey block and turn it into stone. Move the top right yellow block down into its space. Move the grey block over to the left wall. Move the top yellow block down onto the grey block and turn it into stone. Move the top left blue block down into its space (17)
Level 8
Move the two grey block down against the right wall on top of one another. Move the red block over to the left onto the last available stone. Move the bottom grey block over to the left and into the hole. Move the next grey block on top of the other one. Move the red block down into its space. (19)
Level 9
Move the bottom left grey block down into the first hole. The blue block will drop down. Move the red block to the left past the blue block and into its hole. Move the grey block above the blue block down and into the next hole. Move the next grey block above the blue block down and past the yellow space. Move the yellow block down and to the left into its space. Move the blue block to the left into its space. (34)
Section 2 - Levels 10 - 18
Level 10
Move the bottom grey block over to rest against the right wall. Move the top grey block on top it that one to fill the hole. Move the blue block to the left past the hole. Move the two grey blocks over to the left against the left wall next to one another. Move the red block to the left and down to the left into its space. Move the far left yellow block down into the hole and turn it into stone. Move the next yellow block down into its space. Move the blule block over to the left into its space. (40)
Level 11
Move the close bottom rifht grey block down into the hole. Move the blue block through the yellow block and down and to the left into its hole. Move the left yellow block down and under the open red space and turn it into stone. Move the grey block down on top of the other grey block. Move the red block down and over to the right into its space. Move the grey block to the left into the hole. Move the yellow block down and to the left into its space. (28)
Level 12
Move the right red bottom block to the left into the hole and turn it into stone. Move the left red bottom block to the left into the grey fire and turn it into a grey block. Move it over two spaces under the red space. Drop the top red block down onto the grey block and it will fill its space. Move the grey block to the right through the blue flame and down into its space. (16)
Level 13
Move first red block on left down and over to left into grey flame turning it into a grey block. Move the grey block over under the red space. Move the far right red block down onto the grey block and into its space. Move the grey block over through the blue flame and down into the blue space. Move the yellow block down and into the yellow space. Make sure to move it to the right or else you'll add more moves and get a lower score. (20)
Level 14
Move the blue block over and down into the yellow flame. Then move it down one more step. Move the top three grey blocks down on top of one another till they are just below the yellow space. Move the yellow block over into its space. (29)
Level 15
Move the red block to the right down onto the flame, then down to the next step. Move the yellow block down with the red block. Move the first grey block on the right down to the bottom. Move the blue block to the right and down on the grey block under the red space. Turn it to stone. Move the next grey block to the right down into the hole on just past the yellow block. Move the bottom grey block to the far left to the wall. It will be under the yellow space. Move the last grey block on top to the LEFT and down on top of the grey block under the yellow space. It will turn yellow so you'll need to turn it to stone. Move the yellow block to the left into its space. Move the red block to the left into its space. (43)
Level 16
Move the top red block down into the yellow flame. Move the yellow block now down to the bottom. Move the grey block on top of the yellow block. Move the red block down till it falls on the grey block and then move it over just before the red space. Move the yellow block under the red space and turn it into stone. Move the red block into its space. (21)
Level 17
Move the first grey block down to the bottom. Move the next red block down on the grey block and turn it into stone. Move the the grey stone on the very bottom all the way to the right under the blue space. Move the next red block to the left three spaces till it is on the next step. Move the last grey block all the way down till it falls in the blue space. Move the red block all the way down till it hits the blue flame. Move the bottom block one space to the left. Move the blue block into the blue space. (42)
Level 18
Move the top left yellow block to the right so it falls on the next level. Move the top right red block to the right so it falls on the next level. Move the top left grey block into the hole above the yellow block. Move the top right grey block into the hole above the red block. Move the top left red block down and to the right till just before the red space. Move the top right yellow block down and to the left till just before the yellow space. Move the bottom yellow block to the right under the yellow space. Move the grey block under the red space. Then move the red block above into the red space.
Section 3 - Levels 19 - 27
Level 19
Move the left grey block down into the yellow flame. Then move the yellow block down on the next single platform. Move the grey block above the yellow block on the upper level down to the left and onto the bottom level. Don't go to the right or left yet. Now move the yellow block that's sitting just above it, into the hole and turn it to stone. Now move the grey block into the first blue flame and then over to the left into the blue space. Repeat on the other side: This time, move the right grey block down into the red flame. Then move the red block down on the next single platform. Move the grey block above the red block on the upper level down to the right and onto the bottom level. Don't go to the right or left yet. Now move the red block that's sitting just above it, into the hole and turn it to stone. Now move the grey block into the other blue flame and then over to the right into the blue space. Move the yellow block on top to the left and down to the yellow space. Move the red block to the right and down into the red space. (38)
Level 20
Move the grey block to the left into the blue flame and then into the blue space. Move the red block into the purple transporter and it will drop into the red space. (6)
Level 21
Move the yellow block to the right into the grey flame then move it down and to the left into the purple transporter. Now move the red block down and to the right into the red space. Now move the grey block to the left into the other purple transporter and it will drop next to the yellow flame. Move it to the yellow flame and then right into the yellow box. (16)
Level 22
There are four grey blocks. Move three of them down into the empty spaces to make a path. Move the last grey block down just into the first space at the end of the upper level. Now move the red block along the path to the end block. Don't drop down yet. Move the right grey block to the left just under the red space. Now drown down the red block and over to the left into the purple transporter and it will drop into the red space. (34)
Level 23
Move the yellow block through the red block down to the next level and to the right one space. Move the grey block down into the hole just below the red space. Move the red block into the red space. Move the grey block to the left into the purple transporter. Then move it one space to the left. Move the yellow block to the right into the other purple transporter and when it drops on the grey block turn it into stone. Move the grey block into the blue transporter, to the left through the yellow flame and then down into the yellow space. (23)
Level 24
Move the top yellow block to the left. Move the top grey block to the left onto the yellow block. Move the bottom yellow block into the yellow space. Move the remaining grey block down to the bottom level into the purple transporter. It will show up on the top right level. Move it down and to the left through the yellow space and into the blue transporter. It will now be on the top left level. Move it through the yellow flame and then down into the yellow space. Move the grey block down into the hole below the yellow space and then move the yellow block into the yellow space. (42)
Level 25
Move the yellow block down and enter the right purple transporter. Move the yellow block through the red block and through the blue flame and down to the bottom level. Keep the blue block here for now. Move the red block down into the red space. Move the top red block LEFT and down to the next level. Move the other red block LEFT into the blue transporter. It will now be grey. Move it left into the space above the red block. Now move the blue block left into the purple transporter. Then left into the blue space. (19)
Level 26
Move grey block left down into hole. Move yellow block left down to first purple transporter. Then move it down into hole on top of grey block and turn it into stone. Now move grey block right into blue transporter, then left all the way down into next blue transporter. Now move it left and down into hole. Finally move red block left into purple transporter and then left into red space. (20)
Level 27
Move left yellow block to the left and down to bottom level, then left into the purple transporter. Move it left and through the grey flame then all the way to the left till it falls into the hole through the blue space. Now move the blue block right and down into the blue transporter, then left into the blue space. Now move the yellow block to the right into the red flame and STOP. Now move it two spaces back. Move the grey block all the way right till it falls in the hole. Then move the red block right and into the purple transporter, then right down into the red space. (30)
Section 4 - Levels 28 - 36
Level 28
Move red block to the right one space and stop. Move the left grey block down into the yellow space. Move the yellow block to the left one space and stop. Move the grey block down into to the red space. Now move the bottom grey block (which is in the yellow space) over to the left one time. Now move the red block to the right into the red space. Move the lower grey block into the blue flame and then back to the left against the wall. Then move the remaining grey block left into the purple transporter and to the right into the hole. Finally move the blue block to the right into the blue space. (25)
Level 29
Move the yellow block left to the block in mid air. Move the red block left into the empty space and then the grey block on top of the red block. Move the yellow block left into the purple transporter. Then move the yellow block right down into the hole and turn it into stone. Move the grey block right into the purple transporter. Move it left into the yellow flame and stay there. Move the red block to the right and down and then left into the red space. Move the yellow block right into the yellow space. (21)
Level 30
Move the red block to the left twice. Then move the grey block left till it falls on a grey block and forms a bridge to the blue transporter. Move the blue block down into the blue transporter. Then move it right and down into the blue space. It will pass through the red block. Now move the grey block down and into the blue transporter. It will now be yellow. Move the yellow block down and into the first purple transporter, then over into the yellow space. Move the red block down and into the final purple transporter and it will drop into the red space. (31)
Level 31
Move bottom right grey block down to the lowest level. Move the remaining grey block on top of the yellow block. Move the red block over to the right and down into the yellow space. Then move the yellow block on top of the red block - it won't merge because of the space holder. Now move the grey block over to the right and into the blue flame and stop. Now move the red block to the right into the purple transporter. The yellow block will drop into the yellow space. Now move the grey block left into the purple transporter. Then move the blue block to the right and down and then left into the blue space. Finally move the red block right and down and then left into the red space. (25)
Level 32
Move first grey block (under red) down to the bottom level and to the far right. Move the red block down into its space. Move the upper grey block to just before the purple transporter. Drop the yellow on the grey block and turn it into stone. Move the top grey stone into the purple transporter. Move that grey stone now into the next purple transporter. Move the bottom grey stone on the left, all the way to the left into the blue transporter. Now move the remaining grey stone into the other blue transporter. Move the grey stone down into the yellow flame. Now drop the red block down and to the left into its space. (25)
Level 33
Move the yellow block down into the red space, then left onto the ledge. Move the front grey block down into the green transporter, then right into the hole. Now move the blue block across the grey block and stop. Move the red block down into its space. Move the top grey block into the yellow flame and stop. Move the yellow block on the ledge down under the blue dot. Move the bottom grey block to the right into the blue transformer, then right into the purple transformer, then left under the yellow space. Drop the top yellow block on the grey block and turn it into stone. Move the grey block under the blue space. Move the blue block left into the blue transformer. Move the yellow block left into the purple transporter. (28)
Level 34
Move the right grey block all the way left and down to the bottom. Move the yellow down on the grey block and then left one space. Move the top grey block down on the bottom grey block. Now move the red block all the way to the left, down and over into its space. Move the first grey block on the bottom over to the right into the purple transporter and then over one to be under the blue dot. Move the other grey block on the bottom under the yellow space. Move the yellow left into the transporter and then right into the purple transporter. Move the left grey block right into the blue transporter. Move the right grey block left into the purple transporter, then left into the blue flame and then right and down into the blue space. (37)
Level 35 (HELP!!)
Level 36
1. move grey block on ground on the left hand side over one more to the left so it is sitting right in the corner.
2. Move red square in top left hand corner over one so it falls on top of the grey block and turn that red block to stone
3. Move the grey block that's on the ground underneath the stone you just turned to stone - move that to the right into the blue transmitter tunnel. When it arrives, immediately move it to the right hand corner on the ground. It should now be in the bottom-most right hand corner of your screen.
4. Move the grey block on the top left hand side (top left corner of screen) over one so it sits on top of the block you just turned to stone, and then move it into the pink transmitter tunnel. It will land right on top of the other grey block you have put there. Immediately move that upper grey block into the blue tunnel to its right.
5. That grey block will arrive in the middle of the screen in the right corner. move it to the left so it's next to the pink whirlwind dot, on the right hand side, so that it is in place for one of the red squares to fall on top of it. Move one of the red blocks there on top of this block, and immediately turn that block to stone. Use that same grey block that's there (underneath the one you just turned to stone) and move that to the left, drop it off the end of that layer and move it then to the right, into the pink transmission tunnel. It arrives on top of the yellow block on top right hand side of screen. Immediately move it over one move, so that it drops to the ground. Leave it there.
6. Move the yellow block to the left and move it over the grey block, into the blue transmitter tunnel.. It arrives in the middle of the screen, just to the right of the red block. Leave it there for now.
7. Go to the grey block in the top right corner of the screen, and move it through the transmitter tunnel to its right. It appears on the ledge just below the red and yellow blocks. Move that to the right, position it under the yellow square, and then move the yellowo block into that square, and it turns to stone.
8. Move that grey block over one more time so it's right in the corner, underneath the red square.
9. Go to the bottom right hand corner of the screen, to that grey block, and move that left into the pink transmitter tunnel. It arrives in the middle of the screen - all you do is move it over to the right one move, so that it sits on top of the grey block, and then move the red block into place. Voila!
Hello! This is the solution! Move the red block (top right), two movements to the right, two left (stay near the blue carrier) The gray block in that area, move to the right (left on the block we just moved) and two left on the conveyor Pink (Total 7 moves) On the same block, move two to the left in the yellow square. The yellow block center of the screen, move one to the left, and do stone. (10 movements) The yellow top, move one to the right and three left (stay on the gray block that we have moved before The gray top right, move one to the right and three left, leaving the yellow we've moved now (18 movements) Red out there with blue, move left a will on the gray. The gray stone that moved at first, move one to the left, the transmitter pink (red and yellow blocks, and stones are now) the yellow block from the beginning, we passed by the blue transmitter, and we will rock. The gray block, so we rose to the transmitter (22 movements) We spent the red block to the transmitter blue, and this in turn, we move to the right until the red transmitter. Total, 30 moves! :)
K, stuck on level 30, tried to follow directions above but stuck at very beginning. you said: "Move the red block to the left twice. Then move the grey block left till it falls on a grey block and forms a bridge to the blue transporter", but if keep going with grey block it will turn into a blue block???
How many moves for level 18?
I do it in 62 and it shows 5 gold stars. But when I look back in the menu it does not show 5 gold like it does for all the other mastered levels.
level 35:
move grey block in bottom left corner on block left (so it's against the wall) and stop. Move red block in top left corner over 1 right so it falls on top of the grey block and turn it to stone. Move 1st grey block right 3 squares so it falls into the blue portal then move it 2 more squares to the right so it is against the wall. Now move the other grey block one square right so it falls onto the stone you made and into the purple portal then into the blue portal that it appears beside. Move it 2 squares to the left and stop. now move the red block that's almost above it on top of it, and turn it to stone. Now go back to the grey block bellow the one you just turned to stone, move it left till it falls then right into the purple portal (it should be on top of the yellow block in the top right corner). Move it one square left so it falls and stop. now move the yellow block into the blue portal. and leave it there (should be beside the red block near the middle of the screen). Now move the grey block in the top right corner into the purple portal, then 2 squares right so it is under the yellow box, then move the yellow block right into it's yellow box. Move grey block right once more so it is in the corner. Now take your grey block in the bottom right corner and move it left into the purple portal and right one so it falls into the open space at the right. Now just move your red block to the right till it hits the red box. And your done. 35 Moves, 5 stars.
Level 36:
First bring yellow block in the middle of the screen (with a grey on top) down into the hole, and turn to stone. Next take the red block in the top right move right through the fire, drop down, left 2 drop down and stay. now move grey block on right side, right one so it falls on top of the yellow, then left 2 so it drops into the purple portal. now move it left 2 so it's inside the yellow box (don't go into the portal yet). Now take the yellow block that's in the middle of the screen and move it left 4 spaces so it's on top of the yellow square. Now take the grey block that's roughly in the middle of the screen, drop it down (one right) then left 3 spaces so it's inside the red box. Take one of the red squares and drop it onto the grey block you just placed. You should now have red, grey, yellow, grey all on top of each other. take the bottom grey and move it one left into the portal. your red and yellow blocks should have fallen into their boxes with a grey one trapped. Now take the yellow block that has been patiently waiting beside the blue portal, move it one right and it should fall on top of your free grey block, now turn it to stone. Take your free grey and move it one left so it falls into the purple portal and don't move it. Lastly take the one red your have left at the very top move it left till it falls and go into the blue portal, once it's fallen move it right into the red box. All done :) 30 moves, 5 stars. Hope this was helpful to you!
"Level 31
Move bottom right grey block down to the lowest level. Move the remaining grey block on top of the yellow block. Move the red block over to the right and down into the yellow space. Then move the yellow block on top of the red block - it won't merge because of the space holder."
This doesn't work on my Samsung Galaxy GS II. The yellow block falls into the same space as the Red block so you cannot move the remaining black block across the gap. :/
my phone did that too sometimes. sometimes it worked and sometimes it didnt. you just have to keep trying it. the only way it did work is if you put the red block onto the yellow square then try to move the yellow square and vice versa. and honestly this was the only way i could figure out to beat the level. keep trying and it should work....eventually
im not sure what to tell u then. i will check the level for an alternate solution and let u know if i find one. be fore i do. can u just turn the block to stone? or do u need it later. it has been a while since i played. also there was an update a few days ago. maybe it will help if u update, says its compatible on more devices now, maybe this was your problem. anyways if u dont write back saying the update worked ill let u know if i find a different solution
hiya, it works now
thx for following up, it would be impossible any other way - spent so long decided it was impossible - literally tried every possible combination of moves
was kinda shocked to see info on 35 and 36!
any body knows walk through for level 24 in world 2 game ??
Here it is....
1. Move the top red block to the right 1 space.
2. Move the grey block right 3 spaces so it falls on top on fallen red block.
3. Move the red block, 2nd from right, left 1 space so it falls on top on the grey block. Turn it to stone.
4. Move the new 2nd red block from right left 1 space, right 1, so it is next to the red block.
5. Move grey block left 1, on top of new red block.
6. Move the red block that the grey block was just on, left 2 spaces.
7. Move the grey block left 1, on top of red block.
8. Move the red block on the top right left 5 spaces, so it falls on top of the grey block, and turn it to stone.
9. Move the bottom right red block left 2 spaces.
10. Move the grey block left one, on top of red block.
11. Move the bottom right red block left 2 spaces.
12. Move the grey block left 1 space.
13. Move the top red block right 1 space, so it falls on top of the grey block, and turn it to stone.
13. Move the grey block into the transporter.
14. The rest is self explanatory...total of 44 moves, 5 stars.
Have fun! And I need help with level 29...lol
Here it is....
trying to figure this out but with this i still cant solve world 2 level 24
trying
Babydoc- basically, u just have to keep the grey block on top of the fallen red blocks at all times, moving the red blocks through each other on the bottom level. Let other red blocks fall on top of the grey block, freezing them, so it will create a future path for through grey block to follow to its "home" after entering the transporter.
Now, does anyone have the walk through for level 29 of world 2?
Nevermind...just solved it lol. It's so easy once it's completed, you wonder how it even stumped u in the first place!
