MSG tone
Hello suru :hello: - welcome to Android Forums.
The easiest way I know to do this is to make a new folder on you SD Card called "notifications", no quotes, no caps. Then just put the .mp3 in there. Now that .mp3 should be available to you as a selectable notification sound.
Note: This can also be done for "ringtones", and "alarms".
Hope that helps! :)
Welcome to the site, i will direct you to your device forum, what carrier are you with ??
