b_randon14
Android Expert
So I just want to post this here to see if anyone knows what may be going on or has had this happen to their Triumph.
So about a week ago I had to pull the battery on my phone because it had frozen. I had been running CM7 for months with no issues like what happened when I pulled the battery. After turning my phone on it said it was no longer activated. It had changed my msid number to a bunch of zeros with 2229 at the end.
So I flashed back to the stock rom in order to reactivate and the activate app errored out with 06-07-5920 as the error code. It was because the msid number was wrong. So I called VM and had them give me my msid #, which I wrote down lol, and manually programmed it in using the dialer code ##VIRGIN#. After rebooting, my phone was activated, but I never got a 3g connection.
And ever sense then, and like 20 tech support calls, countless stock Rom reflashes and data wipes, still no 3g since this first happened. And randomly if I reboot my phone it will change the msid back to the 0's with 2229 at the end and my phone will be un-activated! It is crazy I have never seen anything like this and VM can't figure anything out, no surprise there, so I'm trying to get them to replace the phone!
I do jot believe this had anything to do with running cm7 as it ran fine for months, but has anyone had this happen or heard anything like this? No 3g and constantly re-activating my phone is very annoying. Any ideas out there guys?
