Help MT wont Sen out texts receive them or receive calls
jose224
My Motorola triumph wont rexieve calls wont send or receive texts but I can call out I need some help I'm on cm7 tg reloaded
Sounds like you might have to contact Virgin and get your services re provisioned, but without more information, like when did this start, what did you do, if anything, to create the issue, it's difficult to say.
OB
Call VM, request that they reset your sockets, after 5 days with speaking to Tech Support on this issue, they strolled through a plethora of "fixs" i.e.: Refreshes, Hard Resets, Manual Programing, Network Resets, & finally the Socket Reset. The last of which got me back up and running.
Their also seems to be an issue with CM7. I do not know what it is exactly and i have not done any troubleshooting with the MOD (do to the fact that my MT is my primary phone and i need it functioning) restoring to STOCK would allow me to receive messages and all was fine for hours, until i decided to re-flash CM7 which would work for small intervals at a time but then fail. I then upgraded to CM9 and have no other issues. (with the exception of a few send errors) Hope this helps your solve your debacle
ive had the opposite experience as u which always led me to believe its a problem between the phone and VM goofy network, for me running stock every message someone sent me would take 48 hours for me to receive, Every message, and as far as SMS they didnt work period incoming or outgoing, the first CM Rom i ever used was TG-reloaded and it worked wonderfully while having the most amazing battery life ive seen in any rom so far, under the cm7 my messages began working right again and my SMS actually started to work which i tried many times and failed to get working on stock
currently tho im running the mt-dev cm7 due to the fact that it still has devs and has many many updates compared to tg's one major update being tg reloaded is CM 7 or CM 7.1, while the MTdev team updated theirs to CM7.2 Final
as far as the OP since it looks like ur going to need to call VM anyway id try reflashing a rom, maybe even stock then back to a cm 7 just to see if something didnt take or install as it should have
