i was gifted a MT4G it wont go past the first screen that says my touch 4g it constantly restarts over and over ... i have tried putting the pd15img.zip on the sd card .. it reads it a lil blue bar fills up then nothing happens .. if i hit power it goes back to the boot-loader menu but nothing different happens if i hit recovery it just continues to boot loop and if i hit factory reset it continues to boot loop.
i will note that when i first did the pd15 ti said battery is too low change a battery but i let it sit for about an hour on the bootloader and the battery charged....
everything i find on how to fix the phone requires you to be able to access more than the bootloader .. please help here is the phones info i was told it was never rooted and it just started doing the loop .. he said before it would do it but if you pulled the bat and replaced it would boot.
GLACIER PVT SHIP S-ON
HBOOT-0.86.0000
MICROP-0429
RADIO-26.03.02.26_M
eMMC-boot
sep 27 2010, 11:12:59
HBOOT-0.86.0000
MICROP-0429
RADIO-26.03.02.26_M
eMMC-boot
