MTK - CPU Control - For MT6573 - Over/Under-clock your fone to some extent .. :)
Status
Not open for further replies.
ravinOrion
Requirements: Android 2.3.X +
Overview: MTK CPU-Control is a tool to set CPU frequency of the famous MT6573 CPU from Mediatek.
Well, m using this stuff for almost a week with no issues ... works well n smooth ... my settings are ...
all max values set to 299
all min values set to 299
scaling to Powersave
well, other factors are like i am using my phone as a phone , messanger , live chats n few media stuff n customizations ... see if it works smooth with you as it is with mine ... :)
NOTE: This app currently only supports MT6573. This CPU is able to run at 806MHz at maximum. Please get the testing-version of this app to make sure that your system is supportet and that your CPU remains stable at maximum frequency.
MTK CPU-Control was developed because similar tools like SetCPU don't support this CPU which is widely used in most currently available dual-SIM-phones.
MTK CPU-Control can be used to overclock CPU to get more power or to lower the clock to save energy.
MTK CPU-Control provides a CPU-Monitor to show current state of the CPU in Taskbar, dynamic frequency changing for optimized balance between maximum power and best battery-usage. Profiles can be configured for different CPU-behaviour under special conditions (Screen off, Low Battery).
More features like widgets and Voltage-Control are planned.
Download Instructions: Download MTK CPU-Control 1.2.apk and install it. No Root Required.
Status
